MAP Sensor, square wave output?
Old Mar 11, 2004 | 07:34 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
Anyone got experience with what the output of a typical GM 3-terminal MAP sensor is? I want to experiment with using one as an electric vacuum gauge. I believe the output is a square wave, the duty cycle changing with pressure (vacuum), it's not a linear voltage out.
I also understand that they run on 5 Volts, is this correct?
If anyone is interested I can post what I learn from this experiment.
Old Mar 11, 2004 | 09:28 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
all you should have to do is read the voltage between the 5v refrence and computer input wires. theres a chart in the service manual that lists voltages according to pressures.
Old Mar 12, 2004 | 09:44 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Your dead on with the square wave. Im curious to know how you plan to use the square wave to run a gauge. I think they work on a higher frequency being a higher vacuum.
Old Mar 12, 2004 | 01:27 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
With any luck I can find out this weekend just what kind of output the MAP produces. I was hoping that the frequency is constant with varying duty cycle, that's easier to work with. An integrator circuit would produce a DC value that a regular meter can work with. If it is varying frequency then I can't see an easy solution, it would require a tachometer type circuit.
Old Mar 14, 2004 | 01:27 AM
AM Racer's Avatar
Typical map for a non boosted application runs on 5 VDC with a variable 0~5 volts DC out based on vacuum level.
Old Mar 14, 2004 | 07:26 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Most MAP sensors generate a voltage that drops as manifold pressure drops and vacuum rises. Typical readings, 0in-Hg=4.5-4.9 volts, 5in-Hg= about 3.5-3.8 volts, 20in-HG about 1 volt.
Old Mar 14, 2004 | 10:13 AM
dankhound's Avatar
Car: 91 RS
You guys are talking about a completly differnt type of sensor. This sensor will read only 5v or 0v and nowhere in between. If it was the good ole 2 wire sensor it would be easy to rig up a gauge.
Old Mar 14, 2004 | 10:59 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Old Mar 14, 2004 | 11:01 AM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
AM Racer and Danno are correct, the sensor runs on 5 volts and the output is a voltage that varies with pressure. I can see from the Haynes manual schematics that it is illustrated as a potentiometer internally, so it acts just as the potentiometer on the throttle position sensor.
I don't know where I heard the square wave theory, maybe that's a Ford thing??
Old Mar 14, 2004 | 11:03 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If it is a PWM signal it's simple enough to use an integrator, like you mentioned. I can't see it being variable frequency, since that would probably require an external clock. Even so, there are frequency to voltage converter ICs available, like the LM2907.
Old Mar 14, 2004 | 02:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Honeywell also has a whole family of silicon pressure transducers that might do what you want for less cost than a MAP sensor.
Old Mar 14, 2004 | 05:31 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Yeah, it's the Ford MAP sensor that generates a square wave, from approx 90 to 170 Hz depending on manifold vacuum. That's a three terminal device too.
Apeiron, I've seen the pressure transducers you talk about. The reason I'm interested in the GM MAP sensor is because I've got 2 or 3 of them and they're readily available at the wreckers, they're rugged, and you can screw 'em to your firewall and just run them off a 3-terminal regulator. They're engineered to survive under the hood.
I didn't make it out to my folks' to pick them up so maybe next weekend I'll check 'em out and see if the three act consistently.
db057
Jan 10, 2020 08:55 PM
bbsr72
Apr 2, 2016 09:12 AM
customblackbird
Oct 1, 2015 04:30 PM
tuningnewb
Sep 23, 2015 07:06 PM
roysatikas
Sep 22, 2015 08:15 PM
