Another governor question
Car: 1992 Camaro RS
Engine: (LO3) 305 TBI
Transmission: 4spd
o.k i know this is a common question, but i need help. I did A little research and found out the ECM PRom has something to do about it. I also heard you have to reprogram it and all that jazz. So i need to know is this true and if so how??
Car: 91 RS
Engine: 305 Tbi (L03)
Easiest way to get rid of it is in the tech articles. Basically you just wire a switch to cut the wire between the speed sensor and the cpu.
If your talking about actually reprograming your cpu head over to the Diy Prom board.
