fuel pump relay connector
Old Mar 14, 2004 | 05:25 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Ok small problem I spotted today. I noticed that the wires going into the connector to the fuel pump relay were exposed. Ok no problem, I thought i could just push the sheathing up or just repin the wires in the connector. So I disconnect the relay & see that the connector is kinda burnt & melted. Now I wanna replace the connector. So my question is, who sells these connectors along with new pins?
Old Mar 14, 2004 | 07:15 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
They are all like that, don't know why. From the socket they are bare about a half to a quarter of an inch. I just covered them with dielectric grease. Try www.acdelco.com they have a good list of all replacement parts. tried to get the # for you but the server was down.
Old Mar 14, 2004 | 05:40 PM
Car: 89 RS
Ok I thought maybe I did this by pulling too hard on the wires. Weird that other people have this too. I'll post a pic later to show everyone what I mean.
Old Mar 14, 2004 | 08:46 PM
MikeS's Avatar
For the record, mine show a bit of bare wire there also. I'm sure it would be a good idea to work on that to make sure I won't have any come loose. Now, where did I put that motivation?
Old Mar 14, 2004 | 10:01 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I had that same problem on my fuel pump relay connector also. Scared the living heck out of me when it blew the 20 AMP fuse under the hood and made me think I was going to have to replace the pump again. Fortunately, I found the fuse before I dropped the tank. I wrapped electrical tape around the each wire until I could get new pins.
Old Mar 14, 2004 | 10:20 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
which is hte fuel pump relay, i need to know this, its a 87 iroc
Old Mar 15, 2004 | 04:44 AM
Car: 89 RS
Hey Trickster. Where did you get your new pins from? Or do you have a p/n for them? Also, do you know where I can get the plastic connector also. Junkyards are limited here in Hawaii so I'd rather get all those items new.
Old Mar 15, 2004 | 06:54 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
if the relay used for the fuel pump is a standard 4 or 5 pin relay, u should be able to buy a whole new relay that comes with the socket and wire ends for under 15 dollars
Old Mar 15, 2004 | 07:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey AcescarrsRS,
I happened to be in peppy boys one day and they had two packs of them hidden behind some other stuff. They didn't stay there more than five seconds after I saw them. I have about four of the plastic connectors laying around my shop. I also have some of them with wires about six inches long and good pins.
Old Mar 16, 2004 | 02:08 AM
Car: 89 RS
Here you go everyone. Figure I post some pics so everyone can get a visual
Old Mar 16, 2004 | 04:49 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Good pics, the socket looks fine. get some contact cleaner hose the thing down then just use some silicone grease. As I said every one is like that, maybe they left them expose for testing, who knows.
Old Mar 16, 2004 | 04:57 AM
Car: 89 RS
Yea, turns out they aren't burnt. Just had a lot of gunk on them. I cleaned it all up & I still feel that those exposed wires are kinda spooky. I'll decide what to do about that tomorrow.
Old Mar 16, 2004 | 11:19 AM
3gc's Avatar
3gc
Car: Z28
Mine are also like that, too lazy to do anything about it though.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
