Trouble code 24 after auto -> T5 swap
Old Mar 20, 2004 | 02:34 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
For some reason Im getting code 24 from my car now that I completed my 700R4 ->T5 swap. Does anyone know what this code means? I looked it up and its the VSS sensor but I dont have a VSS on my car.
It seems like this code is making my car idle high. When I let off the gas to shift, the rpms do not drop down very fast.
Do I need a computer from a manual tranny car?
or how would I fix this?
Old Mar 20, 2004 | 03:40 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is the Vehicle Speed Sensor circuit (VSS) that is on cars with automatic transmissions. Some one else here that has done this swap before could give you a better answer about the computer. You might be able to get by with just getting a new chip.
Old Mar 20, 2004 | 04:03 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
not sure about the code but you probably have to readjust the minimum idle air, i had to do it to mine after the swap, when I unplugged the iac the rpms went to 1500 and I had just adjusted it before i put the 5 speed in. it was doing the same thing as yours (not dropping much between shifts and it idled crappy.
Old Mar 20, 2004 | 05:08 PM
Axle/Gears: 4.10
What is the iac and how do i adjust the minumum idle air?? Im not really familiar with what you're talking about
Old Mar 20, 2004 | 05:36 PM
Engine: hamsters
im not familiar with the v-6 but there may be a technical article on this site for it. the iac is the idle air control.
Old Mar 21, 2004 | 02:14 AM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Is your dash Speedo working? What year is your car? I think some Auto cars had a VSS built onto the back of the dash Speedo.
You might get better info asking this on "Tranny" Tech Board.
Old Mar 23, 2004 | 04:52 PM
Axle/Gears: 4.10
My car is an 87 camaro v6 and the speedo is working. the light only comes on sometimes
gmoutdoorsman
Oct 3, 2015 11:42 PM
Luigytico09
Oct 1, 2015 08:46 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
dusterbd
Sep 29, 2015 08:40 AM
Lmancha96
Sep 25, 2015 08:11 PM
