Look what I found!
Old Mar 30, 2004 | 04:27 AM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
Look what I found!
I think I finally found the cause of my ever-elusive no-start problem. This is the pigtail that connects my coil to my distributor. I took it off and removed the wire loom (in search of the fabled tach filter) and when I flipped it over, this is what I discovered.
The white wire is completely broken through, only being held on by a small piece of insulation. The pink wire is on it's way there too, but is still pretty solid.
Does anyone know where I might find a new one? I can't splice this one back together, as it's broken off flush with the connector.
Old Mar 30, 2004 | 07:38 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
If you brought the connecter to a dealer they would probably fix it with some wire to solder on. You can try to fix it yourself also. there is a locking clip you have to unhook. Use a paperclip from the wire side to try and release it then you can just pull the wire out of the connector.
Old Mar 30, 2004 | 10:30 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Try a local auto parts store..ask for a coil pigtail for your car specifically.Two butt splices or as I prefer solder it onto your existing wires in the car's harness..plug it in..and you are good to go.
Old Mar 31, 2004 | 04:26 AM
Formula_Fire's Avatar
Car: 1992 Firebird
Engine: TBI 305
Transmission: 4L60
I know Painless wiring has them and so does MSD, Holley, and just about every other company out there that sells aftermarket ignitions or wiring harnesses
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Abubaca
Nov 5, 2016 12:22 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
rudolphschenker
Sep 4, 2015 02:41 AM
