tps voltages
Old Mar 30, 2004 | 04:35 PM
jester111's Avatar
tps voltages
hi
I set my tps votage today koeo and koer. The readings were taken with the meter connected to the tps sensor wire but when i placed the ground probe of the meter to battery ground (at battery) the reading increased by .12v. Is there a problem with this circuit?.
thanks
Old Mar 30, 2004 | 04:45 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You normally set the TPS with "KEY ON ENGINE OFF". The voltage range is .46 - .62 volts. This measured between pin "A" & pin "B" of the TPS harness with pin "A" (TOP)as ground and pin "B"(CENTER) as power. Pin "C" BOTTOM) is the ECM signal wire. There is normally a .02 volt increase in the reading with the engine running at idle.
Old Mar 31, 2004 | 12:06 AM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Should not be a problem.
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
327IROC85
Sep 23, 2015 12:11 AM
