compressor
Old Mar 30, 2004 | 07:52 PM
gm hombre's Avatar
Car: 1989 WS6 GTA
compressor
this is my problem,when i turn on my air, the clutch doesn't work but when i connect it to the battery, it works,there seems to be no current coming from the connector, so my question is, is there a fuse or relay that controls the current to the connector to make the clutch work on my compressor? there is freon in it and the compressor is new.
Old Mar 30, 2004 | 08:23 PM
THIRDGEN87's Avatar
Car: 87 FIREBIRD / 89 TRANS AM GTA
Engine: Ls1 / 350 L98 TPI
Transmission: 4l60e / 700R4
Axle/Gears: 3.73 / 3.27
there is a switch that kicks it on and off. should be on the pass. side in back of the silver canister. youll see a wire with a plug connecting to it. this switch activates the clutch with the cycle. if it is bad the clutch wont kick in. my car was fully charged and the clutch would shut off at the lights and a steady cruise. replaced switch now i freeze. lol
Old Mar 30, 2004 | 08:27 PM
gm hombre's Avatar
Car: 1989 WS6 GTA
you mean the switch that is on the canister in back of it?i'll go buy the switch tomarrow, hopefully it will work, thanks third gen 87.
Old Apr 5, 2004 | 02:08 PM
crnsuperduty's Avatar
Car: 88 sc. convert
Engine: 305 TBI
Transmission: Formerly 700-Now T5
Hey, where did you get the switch? I need one two. I have mine jumpered, I think its just a pressure switch.
Galaxie500XL
Feb 1, 2020 04:53 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
