96LT1, Misc Wires going through firewall. Need homes..
Car: 89 GTA
Engine: 350 LT1
I copied this from Engine Swap.......
Swaping 89TPI to 96LT1 My 96 Harness didn't have any connectors they were cut, I have the following wires which If anyone knows where they go in respect to splicing into the 89 harness.. would be greatly appreciated. If need be I can get the colors.
AC Req Sig.
SENS GND
AC Evap Temp
Fuel Pump Cont
Diag Req.
PCM Power +12V
DLC Connector
PCM Power ign +12V
+5V Reference -this is what wiring diagrams say this wire is..??
PCM GND
Fuel Enable Sig
Neutral Switch
Fuel Pump Prime.
AC Req Sig.
SENS GND
AC Evap Temp
Fuel Pump Cont
Diag Req.
PCM Power +12V
DLC Connector
PCM Power ign +12V
PCM GND
Fuel Enable Sig
Neutral Switch
Fuel Pump Prime.
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Aug 5, 2015 11:57 PM
