hatch motor
Old Apr 5, 2004 | 05:56 PM
Erick's Avatar
Car: Pontiac Trans-am GTA, model 1987
Engine: (L98) 350 tpi
Transmission: 4 speed automatic with overdrive
hatch motor
My pontiac gta 87 had a hatch motor, but it doesn´t work. Searching for the hatch motor i found that it was disconnected. But when i connected the engine, it just get hot and did work anyway, so i unplug it.
what should i do? Is this normal? what can be the problem?
Old Apr 5, 2004 | 06:47 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Buenos Noches, Eric.
Pulldown hatchs are problems on these cars. If you remove the panel that covers the motor, you can usually find that the plastic part of the motor that mounts to the back of the car breaks, because it is weak. This either leaves the hatch open a bit and lets rain water into the back of the car and hurts the motor, or the motor sags down and the latch will not catch when you lower the hatch, so you slam it, and it breakes worse.
Look on this site for the Tech articles, scroll down towards the bottom under general repairs, and at the bottom of that heading is instructions on how to repair the pulldown motors.
Good luck
Troy
So Cal
Old Apr 5, 2004 | 09:05 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I wrote that Tech Article a few years back. You'll find the parts you need to repair the hatch pull-down unit available on my web site. Just click on the TDS sponsor link at the top of the page.
Lon Salgren
Top-Down Solutions
zayne0
Aug 24, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
