Turn signals don't work
Old Apr 7, 2004 | 08:27 AM
87project2.8's Avatar
Car: 87 Camaro
Engine: 2.8L V6
I have an '87 Camaro, and the turn signals don't work, but the hazards do, anybody got any ideas on what may be wrong? This is my first F-Body, and I am slowly learning... Please help.
Old Apr 7, 2004 | 12:25 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Check the fuses. The turn signals on my T.A. share a fused circuit with the reverse lights, not the hazards.
Old Apr 7, 2004 | 12:37 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
Also check your signal flasher relay under the dash, next to the "convenience center" that holds the buzzer relay and hazard relays.
Old Apr 7, 2004 | 03:06 PM
88txiroc's Avatar
You will get more responses if you post this type of question in the Electronics forum. I will move it for you...................
Old Apr 8, 2004 | 06:18 AM
Car: 87 Camaro
Engine: 2.8L V6
thanks for moving my forum to a better location.
Old Apr 9, 2004 | 03:49 PM
Stephen Thomas's Avatar
Car: 84 Trans Am
Engine: 5.7 zz430
Like Mitch DoGG said check your relay's, but I am going to go one step farther and tell you it is your flasher relay if your Hazard lights work, like he said go to the convince center which in under the dash on the drivers side, I have found that sometimesthe hazards are on the fold down panel and the flashers are on a separate clip attached to it, they are little silver canisters.
Old Apr 9, 2004 | 06:03 PM
camaro of solar's Avatar
annother thing is make sure none of the bulbs are blown out...a firend of mine learned abotu this when one of his flasher bulbs was burnt out...it caused the others not to work....
Spyder_TheGamer
Dec 25, 2015 05:07 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
