interior lighting
Old Apr 7, 2004 | 11:29 PM
norcalballa's Avatar
Car: 1989 Camero iroc
Engine: 350Tpi
interior lighting
my light that lights up the speed meter and rpm and my gears is not lighting up at all and i want to noe where's the wire to check if it is disconnect or if u guys can tell me how to fix it that will be great thank you
Old Apr 8, 2004 | 11:15 AM
Faded's Avatar
Car: '91 Firebird
There's a gray wire that goes into the back of the cluster and shift indicator for instrument lighting. I'd check that and the grounds.
Do your other instrumnet lights works.... like on the HVAC? If none of the instrument lights work you may want to check the wiring for the dimmer switch. The output from the dimmer is a black/pink on my firebird, and on Camaro's I think it is dark green.
Oh, and check the fuses first. =)
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
