Check engine light driver
Old Apr 8, 2004 | 09:19 PM
ramrod85's Avatar
Car: 85 Z28
Engine: 350/ 290hp EZ-EFI
Axle/Gears: 3.08 posi
Anybody have an idea where this damn thing is located. Just finished installing a 355 to replace the worn out 305 w/240,000 on it. Now the check engine light stays on and according to the service many I need to check C pin on the remote lamp driver module.
Old Apr 9, 2004 | 01:41 AM
jess's Avatar
Car: 85 Z28
Engine: POS 305
take the bulb out
Old Apr 9, 2004 | 08:30 AM
Vader's Avatar
Backing up a step, what went wrong with your 305 that it only lasted 240,000 miles? That seems a little low.
As for the lamp driver, it's right ni here:
Old Apr 9, 2004 | 08:51 AM
ramrod85's Avatar
Car: 85 Z28
Thanks Vader, but the driver I'm looking for is not in the ECM. The ECM grounds pin G to turn the light off. It seems I have either an open line from pin G at the ECM to Pin C at the remote lamp driver, or a bad driver. Goning back under the pasenger side dash to search some more.
Old Apr 9, 2004 | 10:53 PM
flowmasterchevy's Avatar
Car: '91 RS, F41
Transmission: WC T5
how many mile can a 305 handle? i was thinking about retiring mine, but it just has 103,350 on it....
Old Apr 10, 2004 | 12:00 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Is this a schematic of what you are referring to. "X" marks the spot. If you have the GM service manual, it should give you the location of that unit. If you have a haynes or chilton, they may talk about it but I don't think they will give you a location.
Old Apr 10, 2004 | 09:44 AM
ramrod85's Avatar
Car: 85 Z28
I found it. It's under the passenger side dash near the center console. I appreciate the help. Flowmaster, mine was still running ok. The biggest problem was all the oil leaking from just about everwhere. The gaskets and seals had worn out over 19 years. There was a fair amount of slack in the timing chain and the compression was starting to drop off. 19 years and 240,000, not too bad. I hope the 355 does half as well.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
