center-console lights not working
Old Apr 14, 2004 | 07:04 AM
Liquid_Metal's Avatar
Car: Red '89 GTA
Engine: TPI LB9
I have a -89 305tpi gta with manual transmission. There are two lights in the center console that don't light up. One is the light for the thing that shows you where the gears are(manual transmission) ...can't think of a good name for that, hope you know what I mean. And the other light is the one that should light up when you open the "cassette" compartment.
I've checked all the fuses that are located under the steeringwheel and they're okay... Now I'm thinking there might be some fuses somewhere else I don't know about. I've also tested the lightbubls and they work fine so I'm afraid it might be the wireing that's damaged somewhere and that's gonna be hard to fix! Hope it's just a fuse or something simple.
Now I know some of you probably wouldn't give a rats a** about a small problem like this, but it really bugs me and any help would be appreciated.
Thanx in advance!
Old Apr 14, 2004 | 01:52 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It could be that part of the wiring harness has become dis-connected. The light for the gearshift indicator should dim with your instrument cluster. The other bulb in the console compartment is turned on and off with a switch ooperated by opening and closing the armrest; the switch could be bad. If you have an ohmmeter, you can remove the switch and test it.. The only other thing might be a bad or broken ground wire. You can remove the shift plate/ashtray and check underneath it.
Old Apr 15, 2004 | 06:22 AM
Car: Red '89 GTA
Engine: TPI LB9
I have already opend the shift plate and checked the cables... although not very thoroughly, but I didn't see anything wrong. The switch for the armrest was disconnected but that might have happened while I removed the plate, I don't know. But I reconnected it, turned the key, and even toyed with the switch a bit, but still no sign of life. Where would the ground wire be located?
Old Apr 15, 2004 | 07:07 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
same problem
I have the same problem except I have an auto trans and I don't know where to start looking. is there a tech article or somthing about it?
Old Apr 19, 2004 | 10:22 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
bulb in console
I have no bulb or light of any sort in center console. Should I? Its an 88 ROC. Anybody have pics of what it should look like?
Old Apr 20, 2004 | 02:50 AM
Car: Red '89 GTA
Engine: TPI LB9
Camaro and firebirds interior
I think the interior of firebirds and camaros is quite different. So it doesn't supprise me if you don't have any bulb whatsoever. Unfortunately I don't have a pic.
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
