Will i be able to keep my cruise control?
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
Im in the process of planing my eninge swap for this summer. I am going from:
Stock 92 RS
- 5speed
- 305 tbi
- 10 bolt rear w/ 3.23:1 gears
To:
- 6 speed trans from a 93 camaro
- custom 350 , swapped to CARBED
- beefed up 10 bolt rear w/ 3.73:1 ratio and an Auburn Posi unit.
Will i be able to keep my cruise contol w/ the carbed setup? I have everything but the engine in my possestion now, so i cant go back on anything else.
Stock 92 RS
- 5speed
- 305 tbi
To:
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by dankhound
Theres no reason you physically couldnt. You would just have to rig up the vacuum lines and the cable that controlls the throttle.
if you pulled the SES bulb and left the ECM in there, then ran the speedo output (after it goes thru a converter box) into the stock wiring, then the ECM will probly keep cruise operational.
in that case, i think the thing to do would be to keep all the wiring, and just disconnect what you arnt using.
wigmobile
Feb 26, 2025 02:56 PM
