damn relay... Trickster?
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
So I just replaced my damn starter-enable relay (aka anti-theft relay) which cost me $8. I turned the key, and it fired right up. I turned the car off, then tried to turn it on again a few minutes later (after I put everything back together!) and it didn't work. So I think I'm killing relays. What would be causing this? Why the hell won't anything go my way lately? Is this what Hell is like?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Token, Token, Token.......T'warent for bad luck, you'd have no luck at all. I just saw your other post about the hood also. PM me with what you did when you put the starter enable relay in, okay. BTW, you don't happen to have a p*ssed off ex-girlfriend who works as a VOODOO priestess on the side do you.J/K
Car: 1992 Firebird
Engine: forged 357
I'll post what I did publicly, just in case anyone else knows... I took the old relay out (that relay-holder is a bxtch) and took the cover off it to see how it worked; standard relay. I was trying to see if I could find anything wrong with it physically by looking at it, but I didnt see anything. I put the new relay in exactly the way the old one was (theres only one possible way). I turned the key with the interior pieces dangling, and it fired right up. I put everything back together and it didn't want to work again. I do not think there is a short in any wire, because I tried wiggling things to no avail.
For now, I continue to hotwire my car... at least I made it more civilized; there is a toggle switch on it hahaha
:lala:
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There's nothing like a woman scorned, EH! Token. Go to this link, I loaded some schematics and troubleshooting info there earlier. D*MN man, you gotta quite ticking these women off.
https://www.thirdgen.org/techbb2/sho...5&goto=newpost
Good luck and stay out of trouble. Hope you have better luck with the finals than you're having with the car.
Car: 1992 Firebird
Engine: forged 357
Does Murrays take returns at different stores, or only the particular one I purchased the relay at?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I don't have a Murray's here, but if it is another murray store they should honor it as long as you still have the receipt. The various parts stores I deal with here do.
Street Lethal
Apr 30, 2019 12:14 PM
Ragtop Man
Sep 12, 2015 12:23 AM
