Did I do this right!??!
Old Apr 16, 2004 | 06:33 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
I installed H4 bubls in my car(only in the outter 2) with stock harness and now my highbeams(inside lights) are also low beams. This is the wiring diagram I used.
And the after Effect.
Did I do somthing wrong?
Old Apr 16, 2004 | 06:51 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
hmm interesting
are you sure that you wired it correctly >? and didnt do it backwards ?
Old Apr 16, 2004 | 07:42 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
I switched the 2 wires shown in picture. The wire colores were green and red by the way if this helps now green is at the top and red is to the right(looking at where the bulb plugs in).
Old Apr 16, 2004 | 08:34 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Can anyone tell me what color wire does what on the stock harness? Cause if I get this info I can wire it right.
Black - ???
Red - ???
Green - ???
Old Apr 16, 2004 | 10:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I don't know about the wiring on your's, but on my 89. The high is light green, low is tan, and ground is black.
Old Apr 16, 2004 | 10:29 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Ok sounds right the red might be tan it was dark out , and on yours the green is it 2 wires going into the connector? I am pretty sure I have the high/low wires backwards giving the info you gave me thanks a lot Trickster!
Old Apr 16, 2004 | 11:06 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
This should help you some.
Old Apr 17, 2004 | 09:35 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Thanks A bunch Trickster. I had it wired all wrong but thats cause the diagram above is also incorect for the way the stock 4656 plug pins are. But thanks to the Trickster it works!!
