Coolant Temp Gauge Problem
Old Apr 17, 2004 | 02:58 PM
chuck88iroc's Avatar
Car: 1988 IROC-Z Convertible
Engine: 305 LB9
Transmission: MK6 5-speed
Axle/Gears: G80, G92, GM3
I have a problem with the coolant temperature gauge on my 88 IROC-Z. When going to start the gauge drives full scale, like it should, except the needle drives so far it gets stuck on the bezel. Does anyone know if there is supposed to be an internal stop on the gauge?
If the ingnition switch is just placed in the run position the gauge works normal. It is only when the ignition switch is placed in start and the ground is supplied to test the gauge that the problem occurs.
Anyone have some suggestions?
Thanks,
Chuck
Old Apr 19, 2004 | 07:44 PM
Engine: 305 LB9
After checking the system again this past weekend I suspect that the gauge might have an internal spring that pulls the needle towards the cold side. If so I suspect that this spring has broke. Unrestrained the needle swings off the scale when the lamp test ground is applied during engine start.
Two questions I have that maybe someone could answer:
1. How high does the gauge go during engine start? (Quite frankly I never paid any attention to it during engine start. But I know it didn't fly off the scale and get stuck).
2. When the engine is shut-off does the indicator stay down around the cold side of the scale? Mine slowly floats back up toward mid scale or higher.
Thanks,
Chuck
Old Apr 19, 2004 | 07:59 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The gauge sets to whatever temprature the engine is when power is applied (key in 'run' position) because it is now being 'controlled' by the sender. With no power to the gauge, it's free to drift to wherever it feels.
The gauge should, fairly quickly, go to full hot during crank. The gauge is grounded through the ignition switch during crank. This is a 'test sweep' to show the gauge has full range of motion w/o being in a bind.
Ghettobird52
Jul 5, 2024 11:18 PM
Bstrang6
Sep 8, 2015 04:29 PM
TheExaminer
Aug 26, 2015 04:59 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
