Like a cancer... code 33
Old Apr 21, 2004 | 07:54 AM
87TAinVA's Avatar
Hello all
A few months back my 87 TA 350 TPI, AT threw code 33. Symtoms included hesitated while cruising, stalled at stop lights.
Searched the board
Did what was suggested
Changed both relays and then MAF sensor
Problem fixed, thanhk you all
Washed engine bay last weekend, code 33 came back.
Symtom this time is high RPM at idle, stalling at WOT, surging ...
Also, code 21 (Throttle Position Sensor) came up once
Checked all connectors, swapped relays then put a new MAF sensor (Microtech... life time warranty at Trak Auto) to no prevail.
What possible be the problems and what should I do next?.
Thank you all
Old Apr 21, 2004 | 10:46 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Did you look for corrosion on the relay connectors? You did say you cleaned the bay... That would be the first thing I'd look for...
Old Apr 21, 2004 | 10:53 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Also check for water in the connectors and remove water with air gun.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
