16197427 PCM wiring
Old Apr 29, 2004 | 10:00 AM
BigJohnson's Avatar
16197427 PCM wiring
I am retro fitting a TBI setup using a 1995 16197427 PCM. I have rewired everything and have a 99% complete harness. What I do not know what the 16197427 used as a park/neutral input or if it even used one. I am using this with a TH400 so I would like to use the park/neutral if possible. Is there a way to use the park/neutral function with this PCM?
I am going to purchase TunerCat to tune my chip and I also wondered if I can eliminate the trans. controls from the automatic trans bin file?
Also, I wanted to run a VSS. I looked for them and all I could find was a driveshaft reluctor ring type setup. I don't like the way that looks and I don't want to invest money in it. Does anyone know of an alternative for the 4 pulse per driveshaft VSS?
Old Apr 29, 2004 | 11:38 PM
steve8586iroc's Avatar
Johnson, I would love to tell you what you want to know but, I nor anyone else here on the tbi board probably know the answer to your question. I do know that you will or should get more help on the DIY ECM board. What are you putting this into, an older car or truck? One thing you might could do is use a bin from a manual trans then just change the nessasary fields that would relate to an auto trans bin such as fueling, timing. Those type of areas that would be better suited for the auto and the rest would not be trying to shift the tranny for you. As fare as the vss, it looks like your going to have to bite the bullit and spend some cash or get creative and design your on converter.
Steve
Old Apr 30, 2004 | 07:44 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
if you need the 4 pulse per rev or the 2 pulse per rev VSS's, then painless wiring makes an add on unit that screws into the output of the trans, and then into your existing speedo cable. I don't know about 4 pulse per MILE though.
try this link for possible schematics which would give you VSS and P/N info(on the left side, at 'download wiring pics')
http://www.megspace.com/cars/16147060/do_eng_wrg.html
I'm sure you could probably change settings to the trans controls or turn off error codes relating to trans settings. if you are using tunercat, ask if that is included in the definition.
Old May 13, 2005 | 07:57 AM
89350STRO's Avatar
BJ,
Follow this link: https://www.thirdgen.org/techbb2/sho...hreadid=270266
Ben73 has already done what your attempting, I'm sure he can lend some assitance.
89350STRO
Old May 15, 2005 | 02:05 AM
ben73's Avatar
Yeah, I used a 16168625 which is almost identical.
I have some notes that will help you out.
I will repost when i get home ;-)
midge54
Dec 27, 2019 04:14 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
NBrehm
Aug 25, 2015 11:49 PM
mizz0313
Aug 12, 2015 06:45 AM
djmarch
Aug 9, 2015 05:27 PM
