ecu bracket?
Old May 19, 2004 | 11:49 PM
91Z28-350's Avatar
ecu bracket?
What holds the ECU in the car? Mine just kind of dangles there, I'm wondering if there's some sort of bolts or bracket? This is for a 1991 Z28.
Old May 20, 2004 | 12:29 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It should be mounted in a bracket that is mounted to the dash metal support frame by two 7MM bolts. See picture.
Old May 20, 2004 | 08:44 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Mine has a plastic pin on the top facing side of the ECM, and the 4x6 speaker bracket has a piece coming off of it for the pin to slot into to brace the top. I also have the two 7 mm screws on the bottom side.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
KO1
16
Oct 15, 2015 05:00 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
