question about dash harness bulkhead connector
Old May 20, 2004 | 12:27 PM
MotorCityMuscle's Avatar
I want to put a 90-92 style dash in my 89 RS. My question regards where the main dash harness plugs into the bulkhead on the driver side of the firewall. Will the 90-92 harness plug right in to the bulkead on my 89, or does the harness need to be repinned?
I would really appreciate some insight here, as my searches havent come up witha definitive answer.
Thanks in adavance.
Old May 20, 2004 | 12:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here is connector C207 from a 89 camaro, I will try to find the diagram I have of a 92 camaro connector.
Old May 20, 2004 | 04:43 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The connections on the firewall *should* be the same. The block which is bolted to the firewall and protrudes through into the engine compartment is all part of the underdash harness.
TheJoeY88
Dec 31, 2016 07:30 PM
IBrockZ
Aug 20, 2015 12:20 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
