Operating Power Locks Independently
Old May 20, 2004 | 07:53 PM
1986tpiiroc's Avatar
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
Ok, I got a new alarm to replace my old one. It says I can hook it up to unlock the doors independently, push unlock button once to open drivers door, twice for both doors. Now do I have to unwire the relay that controls the locks, cause the wires seem to be running in parallel to both lock motors. If worse comes to worse i'll just leave it the way the old alarm is connected to unlock both doors at the same time. The alarm is a code alarm csi-200 if that makes any difference, old one is a code alarm from the early 90s.
Old May 21, 2004 | 07:55 PM
Car: 1986 IROC-Z
Anybody??? Im probably gonna install it tomorrow. Stupid alarm thats in there now will let me disarm the car, but if I wanna arm or disarm again, after it arms, I have to wait 5-10 minutes before I can give it another command. and yes batteries in remotes are brand new. Ive tried to arm with one remote and disarm with the other, so I know its not the remotes.
Old May 22, 2004 | 12:48 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If I'm not mistaken, the lock switches are wirerd in parallel which control a single relay 'assembly' (basically 2 relays put together on a metal holder plate and wired together to operate the locks). The relays alternate the power or ground (similar in fashion to the window switch) to forward or reverse the lock solenoid (solonoid ?.. I never can get that right) action.
Anyways... you would need to seperate the switches (by rewiring) and then add a 2nd relay assy (again, more wiring) to independantly operate the locks.
Personally, I don't see the effort being worth the ends to operate the locks seperate from each other.
Of course, that's just my opinion and.. it doesn't matter too much
Old May 22, 2004 | 03:08 AM
Car: 1986 IROC-Z
Nope, I Agree with your opinion. It does sound like way too much wiring for something that I dont really need. Right now the current alarm opens both locks at the same time and has done this since I got the car. So leaving it that way wont matter too much anyway. I just hope it wont be too much of a P.I.T.A. to switch the brain out.
Vintageracer
Jan 10, 2020 05:33 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mantaguy
Sep 1, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
