wiring up power locks in a non power lock door
Old May 22, 2004 | 09:47 PM
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
where do i start i want to change from manual locks to power locks
Old May 30, 2004 | 02:07 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
I'm in the same boat too........
I have the control module and it has 3 wires orange,light blue & black wire and the actuator itself has 2 wires grey/tan ,so how do I connect everything and where to?....the tech section has nothing listed and my shop manual is useless!!!...and do I need anything else to add to make this work???....thanks in advance!!!
Old May 30, 2004 | 08:57 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Here. this should clear things up guys.
Attached Thumbnails wiring up power locks in a non power lock door-powerlocks.jpg
Old May 31, 2004 | 01:54 AM
sheltonw3's Avatar
Engine: Classified
Well that really gives us an idea,but I don't have the relay!!!...is there a model number to refer by on the relay module???
Old May 31, 2004 | 08:34 AM
Car: 89 Camaro RS
Engine: 305 TBI
Sorry. Looked in the manual again.. but no part number. I think your best bet would be to inquire at a dealer. Or at least find out where the relay is located, and pick out one at a local yard.
Old Jun 21, 2004 | 06:50 PM
sheltonw3's Avatar
Engine: Classified
Power hook up???????????
okay so far I got everything together and the actuator only "unlocks"....but I don't plan on hooking up into the fuse block at all!...I have two other power wire leads I can use and if they both are seperated and fused will the actuator lock then?...I am trying these theory's on my power inverter first before final installation!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
stalkier
Aug 13, 2015 12:59 PM
