Maybe I can pick yer Brain???
Old May 29, 2004 | 08:40 PM
SickSleeper's Avatar
Car: '90 RS
Engine: 350 bored .30 over
Transmission: blown 700r4
Ok, time for the trouble. I recently swapped from TBI to carb (more trouble then i thought id be getting myself into) neways, i removed the wiring harness on the pass side, since i had removed the AC and heater box a while ago there was no lose there. Traced most wires from the harness then removed it along with the computer. This is where my problem started. Before removal of the computer car was up and running. Sometime along the way i lost the only set of keys for my car. duh. So i raced off to the local dealership only to have them tell me my car had no VATS in it, which it did cuz my old key had the pellet in it, so i tired the non vats key they gave me, didnt work, but the door lock key they gave me worked so i new they had the right vin number. So i figure sumtime along the way someone had switched ignition cylinder, picked up a new one and installed it, relized i needed to bypass the VATS so i jumped the starter enable relay. Now its like the car has a major power drain somewhere, the first turn of the key to the on position yeilds normal results, no security light guages work ect.. once the key is turned to start the starter clicks once like it wants to start it stops the dash lights and everything seem to fade and the buzzer for the open door makes a lower noise, Im totally dumbfounded on this problem, starter and everything is fine had that tested before this swap took place, is there anything that im overlooking?? anything would help me at this point im at my wits end here. thanks guys - jon
Old May 29, 2004 | 09:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Do you have a good, fully charged battery in it.
Old May 30, 2004 | 11:21 AM
Car: '90 RS
yep iv tried the battery out of my truck even, and jumping the car also
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
jaridjohn
Oct 5, 2015 07:01 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
92projectcamaro
Sep 29, 2015 07:07 PM
