Trouble codes
Old May 31, 2004 | 04:27 PM
Erick's Avatar
Car: Pontiac Trans-am GTA, model 1987
Engine: (L98) 350 tpi
Transmission: 4 speed automatic with overdrive
Trouble codes
My gta 87 display the 32 and 34 trouble codes. When I turn un the engine it stops immediately, it just stays idling if I push the gas pedal. This problem is caused by the erros?.
How can I fix it?
Old May 31, 2004 | 08:07 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
With those codes you should still be able to get the engine to rev up if you push the pedal. Check to make sure your cable from the pedal to the throttle body is still connected and functioning.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
