distributor, location
Old Jun 9, 2004 | 09:18 PM
CAMAROPRO5150's Avatar
Car: 88 Trans Am GTA..
Engine: 355 TPI, DONE to the gills
Here we go guys, i have a 92 TPI camaro, wit a 350 ( oringally a 305 )... but i took out the ditributor, and i cant remember the way the thing pionts in the back of the motor, you know which way the hook-ups for the coil / moduler point. i have no clue...i need to find out so i can have my timing right.....how do i figure out which way it goes, or if u can tell me or email me a diagram of it i would really be greatfull....thanks
Old Jun 9, 2004 | 10:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you haven't moved the oil pump shaft, it can only be fully seated in two positions, 180 degrees apart from each other. One of these will be right, the other will be wrong. If you can't figure out the position at all, it'd be best to turn the engine over to #1 TDC firing, use a long screwdriver to line up the oil pump drive shaft, and then drop in the distributor.
86CamaroDan
Sep 29, 2015 10:08 PM
camarohelp
Sep 22, 2015 03:19 PM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
