Holley Stealth Ram and aftermarket TPI wiring harness
Old Jun 11, 2004 | 02:02 PM
S10Wildside's Avatar
I ordered a new Stealth Ram so I could figure out what wire lengths, if any, should be lengthened/shortened for the new TPI harnesses I'm building to specifically fit a Stealth Ram. Turns out Holley put all the sensors in the correct location for use of a stock length TPI wiring harness and nothing seems to be extra long or too short. Even the wiring for the manifold air temp sensor is the correct length and Holley put it in the same location as it is on the TPI intake.
Anyway, just a heads up that any aftermarket TPI harness (and the ones I'm building) will fit the stealth ram with no changes.
Old Apr 13, 2014 | 08:55 PM
birshking's Avatar
Car: 1985 camaro iroc z-28
Engine: 5.7L
Re: Holley Stealth Ram and aftermarket TPI wiring harness
How much for a harness?
9192camaro
16
Feb 3, 2019 12:21 AM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
