Ignition Help!!!
Old Jun 13, 2004 | 04:34 PM
kridgley's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8L
Ignition Help!!!
i just gave my car a tune up ... replaced the plugs, wires, dist. cap, dist. rotor, and some other non ignitions stuff .... it started several times, then i ran it, it ran real good, then after that run ... the engine will not turn over ... the battery and starter solinoid are working good ... any ideas
--oh yeah, its a 87 2.8L TPI
Old Jun 13, 2004 | 05:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
When you say the engine won't turn over, do you mean it won't crank or that it cranks but just won't start.
Old Jun 13, 2004 | 05:24 PM
kridgley's Avatar
Engine: 2.8L
cranks ... but wont start
Old Jun 13, 2004 | 06:11 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check your ignition module under the distributor rotor, it might be barbequed. Also have some crank it and see if you are getting any spark at the plugs.
Old Jun 13, 2004 | 07:00 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Could be a fuel issue or a spark issue. Do the spark check first. Your module could be no good. If you replace it make sure you rub grease on it so you dont fry the new one. It comes with a special grease (dont use just any grease). You could have also blown your fuel pump fuse as well.
Old Jun 15, 2004 | 06:07 PM
kridgley's Avatar
Engine: 2.8L
thanks for your help guys ... it was the ignition coil
---i'm gunna sell it though, i got a great deal on 75 vette .... take care all .... you've been great
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
