What is wrong with my tach?
Old Jun 13, 2004 | 11:50 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Ok this s*** is really pissing me off! When the car turns on it's fine. It idles great! When i hit the gas (and i mean really hit the gas) the tach doesn't run smoothly, the car will but the tach does not. It skips numbers on the way up. Then when i am cruising on the highway when it is at a certain RPM it will just studder and skip. It does not go completly dead. Before i get an after market one what is wrong with the stock one?
Old Jun 14, 2004 | 09:32 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You might need to check the white wire coming off the igniton coil and the coil itself. If the problem is not there, it will be in the tachometer on the instrument cluster. There is a diagnostic connector for the tachometer near the distributor on your car.
Old Jun 14, 2004 | 10:23 AM
ar_mcadams's Avatar
Car: 91 camaro
Transmission: auto 700r4
mine is doing the same thing from 4 K to 6 k. It jumps bad between these numbers. What does the diagnostic connector for the tachometer near the distributor look like?
Old Jun 14, 2004 | 10:33 AM
Engine: 383 Stroker
I thought it might be the coil because its kind of loose. Ok just wondering what it was. Thanks.
Old Jun 14, 2004 | 03:35 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It's a single wire connector with a white wire coming off the ignition coil
$750 L98
Feb 1, 2025 02:25 PM
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Eric-86sc
Sep 28, 2015 11:37 AM
