wiring diagram for steering column needed
Old Jun 17, 2004 | 09:48 PM
Camaroal's Avatar
Car: 98 Camaro
Engine: 441ci LS7
Transmission: th350
Axle/Gears: 4:10's
I am in the process of rewiring my camaro and need the wiring diagram for the steering column for the high beams. I have one wire with a plug that i don't know where it goes. All the lights work except for the high beams,any help would be great.
thanks
AL
Old Jun 17, 2004 | 09:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Do you have a picture of this plug, and if you have re-wired the steering column and removed everything. You may need to adjust the dimmer switch on the steering column. It is located in the same spot as the ignition switch.
Old Jun 17, 2004 | 09:59 PM
Camaroal's Avatar
Car: 98 Camaro
Engine: 441ci LS7
Transmission: th350
Axle/Gears: 4:10's
I don't have a pic of the plug it is clear and comes off the left side of the column at the bottom where all the turn signal wires are. I did not touch anything in the column it is all still stock. I will try and get a pic of it.
thanks
AL
Old Jun 17, 2004 | 10:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I have a feeling that is the wire for the multifunction lever on the column.
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
