yellow and green wires.
Old Jun 22, 2004 | 09:07 AM
turismo's Avatar
Car: 1989 Trans Am GTA
have a 1989 gta with the L98.
car died on me last summer coming off the highway. I just punched it passed some cars. (hot day too)
Next thing that happened is the car stalled out. Stereo was still pumping and lights where on etc.
tried to crank her over and everything turned but did not fire.
took it home later on and had a friend boost it. It started and ran for 10 seconds and then sputtered a bit and died and I have not been able to get it started since. There is some distance involved to where my car is so I need to get a good answer.
so far I've had to put in a new battery because the ACdelco bloated up. also put in a new coil and ignition module because it seemed to be a good idea at the time. also new wells cap and rotor because the ends where black and rusty.
but the car didn't fire after all that.
a while later I noticed the wires that go from the distributor to the module are completely toasted yellow and green). They are barely together. I think they where cracked and some water got on them and they blew to sheit.
not really a car tech or mechanic yet so I need some help.
What are they for exactly? And I have a feeling that's my problem.
new distributor?
and if so from who?
thanks Generel Motors!
sorry for the long story. thanks for any help.
-turismo
Old Jun 22, 2004 | 10:34 AM
3gc's Avatar
3gc
Car: Z28
I can't find a diagram for those wires to tell you what they go to. But you should replace them, it may fix your problem.
Old Jun 22, 2004 | 08:01 PM
turismo's Avatar
does anyone know what the wires are for?
Old Jun 22, 2004 | 08:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Those two wires connect the pick-up coil to the ignition module.
Old Jun 23, 2004 | 06:30 AM
turismo's Avatar
so the distributor has to come out?
beause the wires go right into the housing. doesn't look like any sauldering job will fix that.
thanks for the responses.
Old Jun 23, 2004 | 10:38 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If the terminals and the wires look to be in good shape, you can do like I did two days ago. A friend had the connector fall apart on his 4 cylinder grand am. I got another pick up coil, removed the wires from the connector and put it on his old coil. worked great and didn't have to pull the distributor. If you can do this it will save you time and a lot of headaches. If not the distributor will probably have to come out depending on the type you have.
Old Jun 23, 2004 | 08:03 PM
turismo's Avatar
hmmm.
so new pickup coil. didn't even know I had one
I hope it's an easy fix and the distributor doesn't have to come out.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
