Everything Electrical DIED going down road!!!!
Old Jun 23, 2004 | 06:56 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I was on my way home when my gauges and lights went hay wire and everything died. No power AT ALL. Something shorted under my dash io believe. To get home i ran a wire from the
12v + to the back of my fuse box. My ignition hadnt been working so i rigged up a push button starter for a while. Is there a fusible link in my steering colum going to my fuse box?
You can refer to thishttps://www.thirdgen.org/techbb2/sho...hreadid=220610
Old Jun 25, 2004 | 09:26 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I dropped my car off to a guy today and he found 2 fusible links that had blown going to my fuse box. But hes still trying to fix my ignition. Is there another rely before or after the (theft detterent/starter enable relay)? Does anyone have the schematics for the Fuse and igntion wires?
Old Jun 25, 2004 | 09:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well yes, there is another fuse that should be in your circuit. It is called the "CRK" fuse and is a 3 AMP fuse in the fuse panel.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
