brake lights connected with parking lights?
Old Jul 5, 2004 | 11:38 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
i have had a problem for a while now. my brake lights and parking lights are somehow being connected to each other. when i turn on the parking lights the lower tail/brakelights come on but the third does not. also if i put my foot on the brake the parking lights will come on dashlights ect. if tyhe car is off and i hit the brake the dash buzzer will come on to warn me of my light5s being on. i have checked the whole entire rear harness all the fuses bulbs are correct and i have checked almost all of the wiring from the parking light switch back to the passenger side marker. the only things i have not yet checked are my brake light switch and my rear light sockets. what else could be my problem i am stumped.also where is the ground for the brakelights parking lights? i have seen problems with bad grounds bleeding back through to other systems
Old Jul 6, 2004 | 12:22 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You have a shorted bulb in one of the rear brake/marker lights. It's feeding power back through both circuits.
Old Jul 6, 2004 | 10:51 AM
Engine: LO3 and LT1
all of my bulbs are brand new could it be one of the sockets?
Old Jul 6, 2004 | 01:15 PM
That is another, although less likely, possibility.
You can check the sockets by removing the bulbs (just the ones for the brake lights) and pressing the brake pedal to see if the rest of the parking lights illuminate. If they do, That would point to a bad socket.
If they don't light up, put one bulb back in at a time, and check by pressing the pedal after each one. If the problem re-appears, you have found a bad bulb.
Also, double-check the bulbs to be sure they are the right ones. A 2056 bulb will cause this problem in a socket intended for a 2057.
Old Jul 6, 2004 | 07:53 PM
Vader's Avatar
Check for reliable grounds at EVERY rear lamp socket. It's likely that a marginal ground at the rear of the body is causing current to find a ground through the lamp filaments of other lighting in the same circuit.
Old Jul 6, 2004 | 09:01 PM
3gc's Avatar
3gc
Car: Z28
I had this same problem last year. Turned out to be i had the wrong bulbs in two of the rear lamp sockets. I had a dual filiment bulb where a single filament bulb should have been. Switching them solved my problem.
Old Jul 6, 2004 | 10:57 PM
Engine: LO3 and LT1
ok i removed all the bulbs does it with all the bulbs removed. the only way i can get it to stop is when i un plug the little harness connector in the rear storage compartment. so that would indicate it has to be somewhere past the harness connector right?like a socket or a short in the wires somewhere so how would i check the sockets. and where is the ground for the rear bulbs i cant seem to find one
BRoss99
Aug 10, 2025 05:08 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
