need help with vats problem
Old Jul 9, 2004 | 03:00 PM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
i have a 1989 GTA i thought my starter was the problem i changed the starter 2 times in 6 months.so i went to start the car the other day and the it would not start so i went back out a hour later and it started right up so it has done this a few times in the last few weeks i noticed that when it doesnt start the security light stays on i know that it is only supposed to stay on for a few seconds then go out.is my vats causing the problem? or is the starter going again.please help.o yeah if i wait about 10 minmutes the car will start again.
Old Jul 11, 2004 | 01:48 AM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
sounds like the typical key cylinder issue. ither its not reading the chip or its grounding out.
go to GMpartsdirect.com or your local dealership. the PN is 2603390. i replaced mine last month due to it jammed up and it was also starting to act up a tad. when you replace it you will need a steering wheel puller, a lock plate tool, a small assortment of sockets, and a allen or torx end to remove the cyl.
we didnt pull the whole coulmn apart, we just dropped it, ran the wire down the coulmn and all was good. at the base of the coulmn where the wires come out ther will be this plastic sleve, open it up and it will make running the cyl wires a lil easier. do this after you drop the coulmn. the distance between where you start the wire and it comes out is a total of 7 or so inches believe it or not. ya have any ques i'll be glad to help ya.
i forgot to mention, you will need a new key. take yuor old key so they can get the resistance code and give them the brass blank that comes with the new cyl and thtey will cut you a new key no sweat.
Old Jul 11, 2004 | 08:52 PM
89gta350conv's Avatar
Car: 1989 GTA conv
Engine: l98 350
cheap and easy way out
inside drivers kick panel is the relay. if you by pass relay you will disable the vats system.
Old Jul 12, 2004 | 08:32 PM
1987gt's Avatar
Car: 1989 GTA
i dont believe its the ignition switch i got it out of a 95 bonneville it was in very good shape.are you sure the relay is under the drivers side kick panel someone said it was way up inside by the firewall?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
