Speedo only working 30% of time
Old Jul 10, 2004 | 10:31 PM
91zzzeder's Avatar
Car: 91 Z28 All Original
Engine: LB9
My speedo only works some of the time as my thread subjecct states. It's not a huge deal but my Z28 is mint (65k) never winter driven and I would like everything to work. The speedo works for a while then stops then goes on intermittenly. Reminds me of a bad wire connection. Anyone had or seen this?
Old Jul 10, 2004 | 11:34 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Do you know if it's cable-driven or is it all electrical?
Old Jul 10, 2004 | 11:56 PM
91zzzeder's Avatar
Engine: LB9
Since it is a 1991 Z28 I assume it is all electronic. When the speedo doesn't work, the odometer also doesn't count up.
Old Jul 12, 2004 | 02:14 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Yup, the odometer is driven by the speedo. If the speedometer doesn't work, the odometer won't either, naturally. Keeps the miles off your car though... Crack open the dash and see if any of the cables are either loose or corroded.
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
Wade787b
Sep 29, 2015 01:15 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
