rear defrost 3rd-4th gen wiring
Old Jul 12, 2004 | 12:28 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
does anyone have a diagram for the rear-defrost wiring of both a 3rd gen, or a 4th gen? If you've got both that'd be great, or if you have one or the other that would work too. I'm not 100% if mines working yet, although the light in the 4th gen will come on when the button is pressed, but only w/ the car running, there's no power to it just in the on position.
Old Jul 12, 2004 | 08:37 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That is because it gets it's power from the gauge fuse which is not hot at all times for the momentary switch in the circuit. It also uses the PWR ACC circuit breaker which is hot at all times for the actual heating when the momentarty switch is closed.
Old Jul 12, 2004 | 04:09 PM
85f-bird's Avatar
Engine: 2.8L, LS1
that was the thought on that, do ya happen to have a wiring layout for it?
Old Jul 12, 2004 | 04:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yep!!!!!!!!!!
Old Jul 12, 2004 | 07:38 PM
85f-bird's Avatar
Engine: 2.8L, LS1
awesome, thanks a million...should solve my troubles.
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
