amp rating of battery switch???
Old Jul 24, 2004 | 02:03 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
i moved the battery to the back a while back and it has been working fine. to race at the dragstrip they want me to have a battery switch. so i bought one from advance auto parts. its a calterm battery cut-off switch and the part # is 41860. it is rated at 50 amps continuous and 12 volts dc. an employee told me that a friend of his had the exact same battery switch on an old mustang with a big block and it worked great. before i installed this, i wanted to check with you guys to make sure that this switch would work in my car. i thought the starter used more than 50 amps......so is it ok to overload the switch to start the car? id think the switch would work fine as long as the car started. what do you guys think?
Old Jul 24, 2004 | 04:43 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Think of 50 amp continuous as for a long time. Your starter draws more than 50amps but it doesnt do it for a long time. You should have any problems with it unless you run alot of accessorys.
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Apr 30, 2019 12:14 PM
GTAman
Mar 15, 2019 11:40 AM
Dialed_In
Aug 20, 2015 01:45 PM
