check ignition module?
Old Aug 1, 2004 | 03:42 PM
tomc1500's Avatar
Car: GMC c1500 stepside 1989
Engine: 350TBI
hi,
i've been searching on the board but i can't find it.
how can i test my ignition module?
89 350 tbi
i've got spark on all the cylinders but cil#8 doesn't have a detonation.
could this the ignition odule?
thanks Tom
Old Aug 1, 2004 | 03:44 PM
87Formula4bbl's Avatar
Car: '87 Formula
Take it to autozone, they can check IMs.
Old Aug 1, 2004 | 03:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: check ignition module?
thanks Tom
If you've got spark at all the cylinders but no detonation at cylinder #8 sounds more like there is no fuel going to that cylinder. Just a thought!!!!!!!!
Old Aug 2, 2004 | 10:59 AM
tomc1500's Avatar
Engine: 350TBI
the spark is wet from the fuel so..
i can't check it at autozone because i live in Europe.
i've read somewhere houw you can test the module?
Tom
Old Aug 2, 2004 | 11:50 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are any of your other plugs soaked in fuel? You may have a leaky injector on cylinder #8 that is flooding the plug. Also, if the plug is too saturated with fuel it won't fire very well.
Old Aug 2, 2004 | 12:07 PM
tomc1500's Avatar
Engine: 350TBI
hi,
my other 7 sparkplugs are looking good.
i changed last weekend the plugs and don't think cil#8 have maybe a bad plug again.
i have a tbi so only 2 injectors.
thanks Tom
Old Aug 2, 2004 | 12:15 PM
Car: '87 Formula
Check the plug wire(s)? Other than that, the only other thing it could be is a damaged cap or something. There's no reason the module (or ECM) would cut out #7 from firing only. As long as the valve is opening, that cylinder should be getting air/fuel just the same as the other cylinders, being TBI. If it's not the spark plug I would check those two things.
Old Aug 2, 2004 | 12:17 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
My bad for not seeing the TBI at the end of the 350. Have checked the spark plug wire or the terminal posts in the distributor cap?
Old Aug 2, 2004 | 02:35 PM
tomc1500's Avatar
Engine: 350TBI
hi,
i found out that i have a broke pushrod.
thanks for the replys
Old Aug 2, 2004 | 06:20 PM
Car: '87 Formula
Well, look on the bright side....at least you found out what it was before spending money on replacing parts
BRoss99
Aug 10, 2025 05:08 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
