ignition switch
Old Aug 5, 2004 | 11:50 PM
eddie jr's Avatar
ignition switch
ok, not sure if this is the right forum or not but I tooka guess
For those of you with manual Tranny's, do you have an "accessory stop on your ignition switch?? The book for my 85 says there should be but there isn't. FIrst stop (click once forward from lock) has no power and the second stop is run. There is no backwards stop
Just curious......it's annoying having to turn the car to on to get the radio.
Old Aug 6, 2004 | 12:03 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Does your steering column have the words ACC at the lock cylinder? Try pushing in on the lock cylinder and turning the key to the rear. That is how I had to do it in my 85 Z28.
Old Aug 6, 2004 | 12:09 AM
eddie jr's Avatar
I tried fiddling with it every which way but nothing. I am not sure about the writing though so I will check that .
Old Aug 9, 2004 | 11:07 PM
eddie jr's Avatar
Checked on the weekend.....nope, no writing except "LOCK". THis one has that funky lever to lock it too.
So is this one supposed to have accessories or are there some that don't even though the manual says they all do????
Old Aug 9, 2004 | 11:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Some one has probably changed out your steering column at some point in time. No, they didn't all have "ACC" on them however, all the ones that I have dealt with have been able to turn the key to ACC.
Old Aug 10, 2004 | 01:51 AM
eddie jr's Avatar
So these ones you are referring to went backwards to accesory but did not have ACC on them?? Did they still have that lock lever....do automatics have that lever???
Old Aug 16, 2004 | 09:02 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
no lock lever on 82 trans am LG4 thm200c column i know and wasnt one in these cars that i have had:
84 s/e 2.8L MPFI t-5,
84 z28 L69 7004,
85 trans am L69 700r4
never seen a lock lever on column for the key switch in an f body yet, so far,
nope
good luck
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
luvofjah
Sep 3, 2015 07:08 PM
