headlight motor relay?
Old Aug 11, 2004 | 08:45 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
where is the relay that controls the headlight motors on an 85 trans am. my headlights go on, but they do not go up or down. if you wire them directly to the battery, they work, so it's not the motors. we tested the switch inside the car, that is fine. we can't trace the wires to the relay that controls the headlight motors. does anyone know exactly where this is?
Old Aug 11, 2004 | 10:02 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The isolation relay is mounted behind the right hand headlights. The left hand actuator relay is mounted at the left hand front of the car on the fender. The right hand actuator relay is mounted at the right hand front of the car on the fender. The two fusible links are mounted in the headlight wiring bundle near the left radiator shroud.
Old Sep 13, 2004 | 07:57 PM
Maverick_82's Avatar
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
the isolation relay can be found by reaching in front of the battery in the engine compartment. I just replaced mine today.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
