Turn signal not working
Old Aug 21, 2004 | 06:05 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Ok I'm having problems with my turn signal. The right turn signal blinks fine but the left one stays on and doesn't blink. I checked the fuses and they seem to be alright. Is there a relay or something that I should check? Anyone have any ideas?
Old Aug 21, 2004 | 06:14 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If you replace the burnt out bulb, they'll work fine.
The right side blinking normally means the flasher unit is good.
Old Aug 21, 2004 | 06:15 PM
ffvetteman's Avatar
Sounds like a bad bulb. Check the exterior bulbs.
Old Aug 21, 2004 | 09:01 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Well the problem is the bulb is staying on. It comes on and stays on and the turn signals outside stay on also. If that means the bulb is burnt out, its the bulb in the dash right? Now I'm thinking its a bad wire because it comes on when I'm just driving down the road. **** I don't know, what do you guys think?
specialized
Jun 18, 2022 09:26 AM
Caspar
Jun 19, 2016 11:19 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
