Relay info needed
Old Aug 24, 2004 | 01:18 PM
wetnose's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: L98 350
Transmission: TH-700 R4
Relay info needed
Hey all. One of the relay connectors on my '89 GTA needs replacement. Problem is, I'm not sure which relay this is. It is located on the firewall on the driver's side. There are at least four relays there, some MAF, some fuel pump. This one has 5 in-line connectors and is mounted slightly in front of the other ones. Does anybody know which relay it is?
Thanks.
Old Aug 24, 2004 | 03:25 PM
imghost's Avatar
There is 1 MAF relay, 2 fan relays (if duel fan set up)and 1 fuel pump relay. There is another relay for the A/C as well (should be on the other side though).
Old Aug 24, 2004 | 03:31 PM
wetnose's Avatar
Engine: L98 350
Is the fuel pump relay slighly offset in front of the other ones? That's the one in question.
Old Aug 24, 2004 | 05:48 PM
imghost's Avatar
If there is a loose red wire hanging with a connector on the end, then it is the fuel pump. what color are the wires, that would make it easy to answer your question without a pic.
Old Aug 24, 2004 | 05:54 PM
wetnose's Avatar
Engine: L98 350
Nevermind, found a shop manual...it is the fuel pump relay. The connectors are black, gray. red, orange and green.
RazorN8
Jan 7, 2022 11:44 AM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
