Heat and A/C probs
Old Aug 24, 2004 | 04:37 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
Heat and A/C probs
At first i'd turn it on vent and after awhile the fan would kick on like it was intermitant. NOw you turn it on and nothing happens. I think everything else is fine cause if I turn A/C on the compressor kicks on and when i turn vent on you can feel cooler air trickling out of the vents. I'm not even sure really where the blower is but can you guys help me out. Thanks. Oh it's a 1991 Z-28
Old Aug 25, 2004 | 02:13 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
When you lift the hood the blower is on the drivers side bolted to the fire wall. There's a plastic cover over it. Its right next to the air con. (at least that's where it is on an 82)
Old Aug 25, 2004 | 12:06 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
blower is on the PASSENGER side by the a/c. does the fan work on "high" or not at all? might be the resistor, also located by the blower. also could be the relay...
Old Aug 25, 2004 | 12:14 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
He's in Ireland so it might be on the drivers side for him.
Old Aug 25, 2004 | 12:45 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Give the blower a nice whack with your fist. If it comes on you need a new blower motor. Otherwise youll have to do some electrical troubleshooting.
Old Aug 26, 2004 | 02:30 AM
gholian's Avatar
Engine: 2.8 V6
SORRY!, I'm used to looking at Right Hand Drive cars. Yes it's on Passenger side.
Old Aug 26, 2004 | 06:09 AM
Car: '91 Z28
Axle/Gears: 323's
you got a point there!
Old Aug 26, 2004 | 01:12 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Did it again
Well I went to leave today and the blower worked.
And it is not again so it is intermittent. I'll have to dig into it and see if there is a wire loose or something. Thanks.
Old Aug 29, 2004 | 10:57 AM
Vader's Avatar
I'd check the resistor, relay, control head switch, and blower brushes (in that order) with a voltmeter.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
mfp189
Sep 27, 2015 09:25 AM
