I am going to set the car on fire.
Car: 89 formula 350
Transmission: Stock 700r4
I checked the wires off the batt, off the starter, of the ALT, all are putting 12.24 volts out. IT has a new Batt, and a new ALT, which has been tested 3 times, always putting out 14.4 volts. I have tried everything trickster and the others have said to no avail. A I just going to have to live with this.
Smething I found odd. When the car is not running, battery has 12.55 volts, after I start it, it goes to 12.24.
Also, could this be my belt causing this?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It's possible, what are the range markings showing on the belt tensioner and when you push down on the belt how far does it go down? See picture.
Car: 89 formula 350
I tightened te ground on the batt, was a little loose (didnt notice until no), found another ground that was spliced into. Belt was ok. All in all, I went from 12.22v running, to 12.5 running.
I am running low, but I am holding voltage, not losing anything.
kah992
Aug 19, 2015 02:55 PM
