need advice
Old Aug 31, 2004 | 11:06 PM
RT652000's Avatar
need advice
hey guys hope you can help me. i have an 88 irocz with the 5.7l tpi and the stock hei distributor with an external ignition coil. i need to know how do you remove the metal star shaped teeth which sit upon the pickup coil on the distrib shaft. i would like to replaace the pickup coil itself thanks
Old Sep 1, 2004 | 08:24 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
IIRC, the pickup coil is held down by 2 screws into the distributor, so taking those out is all that will need to be done to get it off for replacement.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
