Looking for a positive lead under dash pad...
Old Sep 4, 2004 | 08:03 AM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
Howdy.
I'm trying to hard-wire my radar detector into my car such that it only has power going to it when the ignition is on (i.e. like the radio). I know I can just pull the negative lead to any ground I can find (and there are lots of 'em under the dash pad); however, I still need a switched positive lead. I know there will be one going to the radio, but I was wondering if there might be one more easily accessible from the top of the dash pad (i.e. so I don't have to dig my radio out).
Any help is appreciated!
Thanks.
Old Sep 4, 2004 | 04:10 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You'll get switched 12V power from the IGN terminal of your fuse block.
Old Sep 6, 2004 | 03:17 PM
sancho's Avatar
Thanks for the response.
However, the fuse box is much too far from where I'm trying to mount my radar detector (in the middle of my dash pad--right above the air vents). I'm trying to avoid having to pull much more than the dash pad off in order to hook this up--and I certainly don't want to pull the whole dash out.
Is there anything closer/easier to get to than the fuse box, or am I just looking at the fuse box wrong?
Old Sep 6, 2004 | 03:27 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Try the fuse panel in the convenience center under the dash by your right knee. Just a thought.
MantyZ28
Nov 8, 2015 06:54 PM
Formula8r89
Sep 22, 2015 04:24 PM
gta_knight
Sep 17, 2015 03:48 PM
gta892000
Sep 16, 2015 12:37 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
