Proper wiring with fuses?
Old Sep 5, 2004 | 03:23 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I spliced into the powe wire for the fuel pump. I am using a 20amp switch and 15amp fuse. Now I was wondering if this is Ok or do I need to go to 20amp fuse. When you wire inline fuses do you wire them a bit lower or a bit higher??
What kind of fuse should I run on the fuel pump power wire (tan and white)???
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
stalkier
Dec 6, 2015 11:25 PM
Dialed_In
Aug 20, 2015 01:45 PM
