VATS - Trickster - I know you know :)
Here is the delema. A friend of mine purchased a 1990 RS (Good Deal but no "chip" key) - got the title signed over to him and walked into the dealership with the original brass key.
The dealer was unable to determine the resistance of the key that was installed in that car and wants to charge hime $35 for each key that is cut and programed (times 15). Isnt that a money making adventure.
I know how to bypass the system if I knew the resistance of the key (that I dont have).
Is the only way to bypass this system by trying 15 different resistors till I get it right?
Will reprograming the ECM for a new key work on the 1990? (20 minute ignition cycling method).
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did he ever start the car and take it for a test drive? PM me on this would you. And not the 20 minute recycling of the ECM wont work on our cars, it only worked on most Buicks.
Car: 1989 Iroc-Z Camaro
Engine: 5.7 liter 350
Your post has been edited because it contains information, that although readily available on the internet, its posting on this board is frowned upon. The original poster of this thread is currently aware of his options via PM. This is not a slap down in any way, so please do not take it as such. You were simply unaware of the policies.
oops, sorry about that, didnt really think about how it could be used...it was dumb luck that i even came across it, thanks for editing and pointing that out to me....i had my ignition thing replaced (by a mechanic, but I bought the parts) a few weeks back...
oops, sorry about that, didnt really think about how it could be used...it was dumb luck that i even came across it, thanks for editing and pointing that out to me....i had my ignition thing replaced (by a mechanic, but I bought the parts) a few weeks back... Last edited by cIaRmOaCrZo28; Sep 10, 2004 at 01:09 AM.
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i had this problem with 1991 rs before i sold it, it my chevy tpi book it said to measure the key with a dvm... i did that and my key read 7.5k ... if u have a dvm, put a lead on the key and the other lead on the piece of black material on the key (clean the key 1st..) and get a reading for resistance....
86White_T/A305
Sep 21, 2015 05:28 PM
