Starting issues...
Old Sep 9, 2004 | 10:31 AM
tc3's Avatar
tc3
Car: 1991 Camaro RS
Engine: 3.1 MPFI V6
Starting issues...
every once in a while when i goto the car and try to start it, when i turn it to on, the lights flash and the only ones that stay on is the security and service engine soon light. When i go to start it the brake light also comes on, the one for the hand brake.
but if i leave the car for a few minutes, and come back, it starts right up.
i was thinking it was a vats problem or something related, the metal connectors on the chip on the key are worn down almost completley, is that the reason, or anything else.
BTW it is a 1991 camaro rs 3.1 v6.
thanks for anything.
EDIT: also my dad thinks that it could be a problem with the car not being in park right, he thinks i messed it up when i adjusted the tv cable, is that a possibility?
Old Sep 9, 2004 | 02:27 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Worn contacts on the key or lock cylinder will cause the problem that you are haveing with it starting. Letting it sit for a little while lets the VATS control module reset itself. Getting a new key from the dealership or a local locksmith that carries those keys should resolve your problem. The TV cable would not affect the transmission cable at the shifter and is a completely different cable.
Old Sep 9, 2004 | 07:19 PM
tc3's Avatar
tc3
Car: 1991 Camaro RS
Engine: 3.1 MPFI V6
ok, thats exactly what i thought the problem was, thanks for clearing that up.
Do you know about how long it takes for the vats system to reset itself?
Thanks Much
Old Sep 9, 2004 | 08:10 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
5 Minutes on the average, no more than 6 unless you sit there and continue to turn the key trying to start the car. Each time the key is turned, the cycle starts over.
Old Sep 10, 2004 | 06:16 AM
tc3's Avatar
tc3
Car: 1991 Camaro RS
Engine: 3.1 MPFI V6
ok, thanks much....
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
