I Need a VSS connector part number or the connector
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Anyone know a part Number for the 2 wire connector that plugs into an electric auto trans VSS? The dealer want $25
No junk yards claim to have one, which is also
. The parts stores claim not to carry them, which in the past I found with coonectors, that if they claim they don't carry, if I bring in a part number then they seem to be able to find one. So if you have a prt number you can give me that would help out alot. Ive also been offered free Vss connectors from people, but I have to wait at least a month on both until these people switch out ther wiring harneses.
. The parts stores claim not to carry them, which in the past I found with coonectors, that if they claim they don't carry, if I bring in a part number then they seem to be able to find one. So if you have a prt number you can give me that would help out alot. Ive also been offered free Vss connectors from people, but I have to wait at least a month on both until these people switch out ther wiring harneses. TGO Supporter
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Your best bet in the junkyards is to go look for yourself. The people working in the junkyards are not neccessarily going to know off hand exactly what you are looking for or in some cases really care. At the ones in my area, they tell me to go look and see what I can find, so I do.
Transmission: 4L60e
Axle/Gears: 9 bolt
I wish I could go look for myself. We don't have any pick your own parts places around here. All the yards around here wont let me go out and look around and claim to not have any f bods in them. What other cars in a yard would have the same vss connector used on ours? ThanX
Transmission: 4L60e
Axle/Gears: 9 bolt
I have a VSS sensor from a 91 or 92 camaro. I need the 2 wire oval connector that plugs into it. I think any year thirdgen that came with an electric speedo has the same plug.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
nope
Just '90-'92 will fit the early ones are different.
Transmission: 4L60e
Axle/Gears: 9 bolt
thanks for that info dyno don. Thatll help make sure I get the right one.
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
sorry to bring this back up but does anyone know the part number for the connector (two pronged) that goes into a T-5 trans so my dash can give me a read out. I also did an entire dash swap thats why I need the connector or number!
1992 Trans Am
May 10, 2023 07:19 PM
IrocZ'85
Aug 17, 2015 06:24 PM
